Need help with AM Tuner!
  • 2
Kibouchi
Hi guys,
First post on here. I actually don't know much about car audio, however with the help of a friend that knows a thing or two I bought a Clarion NX404 for my honda CR-V and we installed it last night. Everything works great except the Radio. We hooked the radio up, and the FM tuners work perfectly. However, when I switch to AM it's mostly static, no matter what station I try and tune to. If you turn the volume up really loud you can faintly hear people talking through the static, so I know some sort of signal is getting through.
This is a pain because my wife's favorite radio station is on the AM tuner and she can't listen to it on the way to work anymore. Anyone experience anything like this? It was working just fine on the factory stereo that came with the vehicle.
So I've tried going into settings and messing with the properties. There really aren't many to mess with and what little there were didn't do anything to change the quality. I also tried consulting the manual, which didn't offer any troubleshooting in that area either. Judging by the fact that the software seems to be functioning just fine, I'm led to believe that it's a hardware issue (something isn't hooked up properly), but we hooked the antenna back in and FM is working great. Is there something separate I was supposed to hook in for AM?
Any advice is much appreciated. Thanks much.
OK - that model has one antenna on the roof for both AM & FM. Are you sure you used the correct adapter and plugged it fully into the new radio's antenna cable?
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
612
11
933
904
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
Kibouchi
Kibouchi
United States
Jepalan
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
