Need help with box for 1 American bass xfl 15
  • 4
So a 6 inch aero port at 16 inches long is fine lol? I'm so confused.
---------- Post added at 02:26 PM ---------- Previous post was at 02:25 PM ----------
What is that program called btw?
You want to avoid compression completely without losing cone control?.. 6 1/2" square with your power... that's what I'd do
no thats a tad high i use fps he used meters u want air velocity under 100 fps.. his is showing u at like 120fps with 6" port., i thought 6"would be good but it's the power u are running thats puts it over the recommended air speed.. u would need 8" port maybe or slot port to keep u around 70 or so fps.. if u were only using 1/2 that power it'd be fine..
what would you recommend a slot port width and length? i still would like 32 hz tuning.
Yeah 8" port... listen to gramps... he's the resident expert... lol!
if you want to use a 6 inch port, go 3.5 cubes. If you want to use 4 cubes you'll want a 7-7.5 inch octoport, if you want to go with an 8 inch round port, you'll want more airspace and they sell 8 inch sonotubes at home depot, you dont need aero flares.
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
665
11
954
Jeepsandbass
Clinton NC
Jeffdachef
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
