Need help with Jensen Flip Out
  • 4
get a new h/u
j/k you can get a little more power out of a line driver if you can find one that will work with your amp.
thats the problem with cheap h/u garbage in garbage out you cant expect a jensen to sound as good as a sony, kenwood, pioneer, alpine, exc. even though the line driver will work your still sending distorted power to your subs
get a new h/u j/k you can get a little more power out of a line driver if you can find one that will work with your amp.
yes.. line driver will fix ur low output voltage...
658
723
958
p3bumpin
p3bumpin
Brier Hill, NY
2002XLT
    May 16, 2024
    May 16, 2024
