Need help with SRT8 Install Sub+Amp install
  • 3
Koltrain129
Looking for some direction on what may be the issue with my install....
I had two L7 12's hooked up to a Skar Audio 1200.1 at 1ohm load. The amp definitely wasn't pushing as much power as I expected. It's hard to explain, but it felt like something was holding the subs back. After a couple of hours of playing time, I smelled burning rubber from the trunk and one of the subs stopped playing. I couldn't get that sub to play again so I took it out and kept the other one hooked up.
I checked the ground and power wires and they all look solid/have good connections. I kept the remaining 12 hooked up and was running it for a couple days with no issue.... I took that SKAR amp out and swapped it with a Kicker CXA1200.1 that was hooked up in my other car (09 Pontiac G6) and it's been playing flawlessly for a week. I can tell it's pushing out the sound/power that I expected in the Charger.
I put the Kicker amp in the Charger and bought a new pair of Dual 2ohm L7R 12 inch subs. I hooked them up in the Charger, and still getting less power/output than I would expect...Similar behavior to the way the Skar amp was in the Charger. Yesterday, I started smelling the burning rubber again so I turned everything down. Fortunately, both subs still work...but I'm getting that burning smell and poor performance from the setup. I checked the ground and power wire connections and they are all solid. I also checked voltage at the battery and it's putting out 12.5 volts. The Power and Remote terminals at the amp are also putting out 12.5 volts.
I'm running this off the factory battery and have noticed that the interior lights dim heavily when the bass hits.
Here's a list of what I have in the Charger right now:
Head Unit: JVC KW-M560BT --- 2V preouts----
Amp: Kicker CXA 1200.1
Subs: Dual 2 Ohm Kicker L7R's wired to 2 ohm load
Here's what I have in the G6 right now:
Head Unit: Kenwood DPX593BT CD Receiver ---4V preouts---
Amp: SKAR Audio RP 1200.1
Subs: Dual 2 Ohm Rockford Fosgate P2's wired to 2 ohm load
Your electrical is part of the problem. 12.5 volts isn't enough for those amplifiers. Big 3 upgrade and a bigger alternator is what you need to upgrade.
Clipping the subwoofers to death trying to get more power than the amp can do cleanly. Skar amp only puts out 800 watts at 2 ohms then after box rise and voltage drop you are seeing alot less power.
Kicker amp does 1200rms at 2 ohms.
Gotta set your gains correctly or you will kill more subwoofers.
I looked at a SMD distortion detector to set my gains, but I don't want to spend that much. Any other recommendations on what I can use to properly set the gain? I have a multimeter and saw that I could use that....but looking for some reinforcement on the best method..
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
608
11
930
903
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
Koltrain129
Koltrain129
St. Louis
Koltrain129
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
