Need help with subwoofer.
  • 1
xlzbx
CarAudio.com Newbie
Wales
Hi,
My subwoofer is an Edge ed7300 twin sub. I had this set-up in my old car which was a Ford fiesta with an aftermarket stereo fitted. Now I have a VW Scirocco with a nice stock stereo. So, because I wanted to keep the stock stereo I ran into the problem of not being able to connect a remote cable or rca left and right from my sub to the back of the head unit. Instead of buying an adapter I decided to buy rca to aux cable. Then to an aux splitter so thay the audio from my phone will play to the aux in the stereo and to the rca for the sub. As for the remote cable I heard that if you connect it to any ignition source it will work, so I connected it to the live wire running from the battery to the sub. The problem with that is it constantly stays turned on so I have fitted an isolation switch to turn on and off.
The sub now works with the stereo in the car but it's out of sync. The subwoofer is about half a beat faster than the car speakers.
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
3K
That's an older sub, pretty sure it was made by Targa and its the Venom line. I remember seeing them back in the late 90's early 2000's if memory...
11
545
663
xlzbx
CarAudio.com Newbie
xlzbx
Wales
xlzbx
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
