Need help????
GRANDV
I have 2 problems and wondering if anyone can suggest what I may need to do.
Problem 1- Passenger side brake light not working. I have changed the bulbs for all the lights and still nothing. The driver side works fine. Also, check fuses and the are good. Is there anything thing else I could check or just bring it in to a mechanic.
Problem 2 - My radio (stock) in the van changes station at random, aka by itself when driving. I thought maybe it is getting old (1996 Dodge Caravan), and would like to put in a new headunit, but if it is wiring of some sort, is there something I should check or have it look at by an installer?
Thanks
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif Listing the problems might help:eyebrow: ...//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif just a thought though:crazy:
get a gun, make sure it's loaded, preferably a hand gun as a rifle is hard to handle. put it in your mouth, pull the trigger and your problems are over. writting a note before hand is optional
660
726
958
GRANDV
GRANDV
Ramsey, MN
GRANDV
    May 18, 2024
    May 16, 2024
