need help!!!!!!!
  • 4
can u tell from the pic about whats wrong with it?and what could have caused it?
Would need to see the whole board top and bottom to really diagnose it as well as testing other components of course. Did you have the gain set properly?. Were you running it at a ohm load it wasnt designed for?
i was breaking in subs so i only had the gain about a quater of the way up and was running it at 1ohm
Hmmmm.......double check your subs and make sure they were wired properly.....Did you have it fused properly?. If everything was wired right then its odd for it to blow those components especially if the gain was low....There has to be a problem somewhere else on the board.
the subs are wired right reads 1.1ohmsdo u think it could have been caused by voltege drop?
Thats a good possibility. What was your voltage dropping to?....Possibly just a defective amp. Cant really say much more without seeing it. Try to find a local repair shop, if you dont have one and want me to do the repair just shoot me a pm.
11
660
726
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
959
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
aaronwhitlock3
Hodgenville, KY
sacsking916
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
