NEED HELP!!!
  • 2
lukehester
CarAudio.com Newbie
Okay, i'm new to car audio and need some insight. So i have 2 DVC SA-12 subs @ 2 ohms per coil. My amp is a Ampere Audio AA-2000.1d that is 2000w @ 1 ohm and 1000w @ 2 ohms. The amp is a monoblock so it has only 1 channel, but has 2 positive terminals and 2 negative terminals. My goal is to get 1000 watts to each sub, but i'm not sure exactly how to do that or if it is even possible. From my understanding, the terminals are actually connected. My question is, can i wire 1 sub down to 1 ohm and run it into one positive and one negative, then do the same thing with the other sub, but plug it into the other positive and negative to ultimately reach 1 ohm and 2000 watts?
You could wire them down to a .5 ohm load, but I don’t know if that amp would be stable. Other than that you’re stuck with a minimum 2 ohms. Anyway you could exchange the subs for dual 4 ohm VCs?
11
558
681
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
940
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
lukehester
CarAudio.com Newbie
lukehester
Winfield, Alabama
Marve_Lous
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
