need port sizes Help!!!!!!!!!!!!!!
  • 2
abcdefg
I need the port sizes for 1 new e12a. The box is 2 cubic feet. Want the deminsions for a slot port. 34-35 hz. I also need the port sizes for the brahma. the box is 2.5 cubic ft. and need it to be 34-35 or whatever you all think that it needs to be. also a slot port.
all help is appreciated.
Thanks
Originally posted by abcdefg I need the port sizes for 1 new e12a. The box is 2 cubic feet. Want the deminsions for a slot port. 34-35 hz. I also need the port sizes for the brahma. the box is 2.5 cubic ft. and need it to be 34-35 or whatever you all think that it needs to be. also a slot port.
Thanks
For the e12a Im coming up with a 4x4" port 15 1/2" long , Thats at 2 cubes and would be tuned to 34hz , Remember thats not counting the displacment of the port or sub
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
203
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
154
abcdefg
abcdefg
Clarksville, Tn
abcdefg
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
