need some Battery knowledge
  • 3
Colossus281
Ok i have a hhr and will be putting in a system. The porb is that my battery is in the back so i dont want to do the big 3. I was told that a Shuriken SK-BT60 60ah Battery wolud be just as good. So what do i need to know about having one. Thanks
Its simple fuse 6" or so from alt run power wire threw firewall. Run under carpet fuse right before u get to batt in rear then fuse each wire that is hooked up to an amp. Upgrade ground wire on batt in trunk. Rest is just simple as any car thats the only difference
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
7
Have you spoken with one of the reps? They should have all that info on file.
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
617
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
415
Colossus281
Colossus281
Albuquerque nm
disturbed471985
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
