Need some help/advice
  • 3
jdes28
Maine
So I have an (older) Kenwood DNX7120 DVD/GPS head unit in my 04 Silverado. I've been getting a super high pitch "squeal" out of the blue. When it happens, my head unit starts rolling through the different modes it has, tuner to dvd to video and then stops once it's found a mode in which it "likes". I thought it might be the head unit itself, but I purchased a unit exactly like the one I have (just without the GPS feature) and it's still happens. It doesn't happen all the time with either, just kind of randomly. My local audio shop says its the head unit (without even looking into it). But the same problem with two different units? I don't think its the case. Please give any help or thoughts.
Thanks a ton.
So I have an (older) Kenwood DNX7120 DVD/GPS head unit in my 04 Silverado. I've been getting a super high pitch "squeal" out of the blue. When it happens, my head unit starts rolling through the different modes it has, tuner to dvd to video and then stops once it's found a mode in which it "likes". I thought it might be the head unit itself, but I purchased a unit exactly like the one I have (just without the GPS feature) and it's still happens. It doesn't happen all the time with either, just kind of randomly. My local audio shop says its the head unit (without even looking into it). But the same problem with two different units? I don't think its the case. Please give any help or thoughts.Thanks a ton.
possibly a bad ground try running your own ground to bare metal
^^ THIS, also try a reset button on the faceplate of the deck, and try take the unit out and check all wiring and connections (check inbuilt fuse too)
11
660
726
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
958
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
jdes28
jdes28
Maine
Side Show
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
