Need some help sketchup pros
  • 1
jdawg90
alberta
What's the best way to do these angled boards in sketchup? What I'm doing now is just drawing the inside dimension of the board, using the push/pull to make it 3/4" thick, and then drawing in the corners. Is there a better way?
11
660
726
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
958
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
jdawg90
jdawg90
alberta
jdawg90
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
