Need some help
  • 3
Hello everyone. I am looking for a good set of fronts and rears.
The car is a 2008 avalanche. I want comps in the front, but I want to keep the speakers in the stock location if not well then I'll look at that later. I want rears because I like my sound coming from all sides. I hear passives are probably what I'm looking for for the fronts, but that rears I don't really care if they are comps or coax. The music I listen to is Rap and R&B. any and all help would be great...Thank You
So you have an 800 watt sub (1600 ios a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
7
81
11
688
746
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
969
bizanks27
bizanks27
Myrtle Beach, South Carolina, United States
bizanks27
Dylan27
    May 19, 2024
Dylan27
    May 18, 2024
