Need Something to keep up with SA-12's
HomeLite
Hey everyone,
Ok, so, I was thinking about putting in 3 8" pro mid drivers in each door and 3 tweeters and call it a day. But I got to thinking that it might be a good idea to have separate drivers for the midbass. Would two 10" midbass, four 8" mids be a good design? Any recommendation for those? Budget will be on the lower end.
Also, what is everyone's experience with tweeter placement? Any tweeter recos? I think I'm more incline to like soft tweeters.
x2 unless you have 6 12's in a wall then that's way too much.
Do multiple soft domes in the A pillars, will have the sound you like and plenty of volume
Hey everyone,
Instead of worrying about "keeping up" (and based on your equipment ideas), perhaps you should consider multiple 6.5's or 8"/4"/1" 3-ways and reducing the sub output to better match your midbass output...something of a compromise between sub/mids.
I'll be honest, I kinda wanted it to be a bit ridiculous lol. Seeing a bunch of cars with like 12 speakers in each door must have gotten me all hot and bothered. But I think scaling down is a good idea too. And that way I could push more towards SQ.
I like the idea of a 3 way system. Would a single 10", 8" and 1" combo work?
I like the idea of being able to change the crossover pattern if I have to take the subs out but still be able to get a decent amount of bass.
Should I get more than a single tweeter for each side? If I mount them on the A pillars, do I aim them at the occupants or at the glass?
My current components, the tweets are mounted at the top of the door and the are kinda meh.
Is Crescendo a good brand for component speakers?
---------- Post added at 10:58 PM ---------- Previous post was at 10:57 PM ----------
Also, how do I keep paper cones dry when I enter and exit the vehicle?
I wouldn't do a 10/8/1 either....maybe a 8/6.5/1 or even better 8/4/1 if you're pushing towards SQ and want to be able to have bass without subs.
I only run one tweeter per side and I like bright tweets but some people run multiples....see what u like. Aiming of tweeters should always be trial and error, we can't tell u that. But we can tell u where to start and personally I think aimed at the occupants might work better.
I'm not a fan Crescendo type mids, I'm more of an SQ guy but people say they get loud and sound good which seems to be what u want. Not sure how deep they dig though.
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
472
366
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
402
HomeLite
HomeLite
Esparto, CA
Why So Cereal?
    May 31, 2024
    May 24, 2024
