SOLD (Needs Repair) IDMAX 12" V3 DVC 2Ohm
  • 1
sumone
Midwest
Bought this sub from a fellow member 2 years ago..worked perfectly up until now.
Here is the thread in which I bought it from eddiem67.
At first I was going to send it back to ImageDynamics but now I changed my mind and just want upgrade...I've had the same system for a good two years now and need to make back some of the Christmas money I spent buying gifts.
NOTE: NEEDS REPAIR
Here is the thread in which I posted that the sub has problems.
In short: the sub would cut in and out every now and then (over the course of 2-3 days), 'til it just cut out and didn't come back on. Grabbed a meter, and measured resistance...both coils showing infinite resistance (open circuit). Looked at everything, looks fine (however, I'm not certified in that department as opposed to someone who knows how a 'bad' sub looks).
I bought it for $275 at the time, I'm willing to let it go for $115 shipped, OBO.
This sub goes for $450 new directly from ImageDynamics here.
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
3K
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Problem resolved - Found a scrap Astra that was fitted with that same unit. Salvaged the Display and original plugs and wired it up on the dining...
Honestly I'd run an audio control DSP or a helix DA helix DSP but if you want to run a app with the DSP that's fine too it's fine too but the LC8...
990
sumone
sumone
Midwest
sumone
winkychevelle
    Jun 3, 2024
