New aftermarket stereo, lost all base in 6x9s in rear deck !Help!
  • 1
mrflynnstone
I recently installed a Kenwood Excelon Kdc-x493 into my 1998 honda accord ex and i have lost all bass sound in the car. Especially in my 6x9s which used to have good sound to them. I have fiddled with the settings on the deck but nothing seems to work, any help is welcomed.
Thanks in advance
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
666
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
782
mrflynnstone
mrflynnstone
seattle, wa
mrflynnstone
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
