Moble Enclosurs 10+ year member
Box Designer/Builder
oh, tripple wowee..... first, i need to start making sure there is not another page before posting, lol, 2nd, i can't belive i read that right. mobile measured the port from the outside, not the centerline?!?!?!?, and 3rd, you went way backwards on that port area. that is only 7.3"^2 per cu, which is absolutely tiny.... like those truck boxes that had the tiny 1.5" round ports in them or even bigger prefabs back inthe day, the ports really did nothing.......... and yours will be highly inefficient and barely effective. at lower power levels, say 300watts, the port will have an effect, but with some ral power, not so much. if you hadn't already glassed it, i would suggest putting it in raw, with just sealant and seeing how you like it. then, when it doesn't reall have the output you expected, then add 1.5-2" width to the port and it will be more than you hoped for.... your tuning and volume #'s were just about spot on, so you are doing good there, just remember lenght of the port is measured down the centerrline of the port, and port displacement also includes 1/2 width of the port beyond.....
Another remark without understanding acoustics........I love it. Yes, most of the audio community will measure centerline, but this completely disregards the high pressure at the bend, therefore without using 45s to control the propagation of the wave, the high pressure area HAS TO BE COUNTED!! The measurement was not exterior, it subtracted the thickness of the wood. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. If he were to put 45s in the line, then yes, a centerline measurement would be recommended. You cannot disregard the portion that causes the most effect in the output in terms of nulls and peaks. A lot of people do not know HOW to account for this, so they go simple.
Do you understand now?
