new guys here and plz school me on my sound stereo noise problem
  • 3
renzovc16
Whats up brothers here is my alternator whine noise problem
I have a 2009 honda accord sedan
Stock headunit with LC6i line out converter
With 2 pioneer amps , a mono, a 4 channel amp
Front polk components
Rear pioneer coaxials
And one 10" rockford fosgate sub
Ran my power wire opposite side from my rcas , but my rcas have my remote wire next to it as well
I have an annoying alternator whine , and some white noise on the speakers, but when i unplug my rcas everything gose away no noise ! Any advice will be highly appriciated it !
Verify ground is good to head unit. If that doesn't help, ground the LOC. If it doesn't have a ground tap, get one that does.
Also make sure your amplifier grounds are very, very good... not screwed to sheet metal with sheet metal screws and not under seat bolts sitting on carpet. You need a solid ground with the paint scraped clean. Shock towers work well.
Thanks for the fast response ! Will check my grounds from my head unit this weekend also will post some pictures of my amp grounds tonight since im prettu sure they are well grounded , i sanded them and drill a hole on the frame and rear shelf of my trunk ! I also bought yesterday a pac ground loop isolator yesterday from sonic elelctronix which had good reviews
Ground loop isolators don't fix ground problems, they mask them. Be sure you exhaust all other possibilities before using an isolation transformer.
Me too and then I have to paddle anywhere I want to go.
6
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
those center spots shine out pretty far enabling me to see well on the dark highways.
22
3K
renzovc16
renzovc16
new york city
renzovc16
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
