New install Help
  • 1
Jadams
CarAudio.com Newbie
NY
Hi guys, New to the forum.
It's been a long time since I installed any type of system. I have a 2013 honda pilot exl/nav. I disabled the active noise control and plan to install Polk MM series speakers in the doors and dash running off the stock unit. (I was told that Honda contracted with Alpine for the head unit)
I am going to install a single 12 with an amp. Planning on 4ga wire from the battery. Also using an NVX LOC for the amp. Does anyone know if I can grab signal from the existing amp/sub in the rear or should I get signal from the rear door speakers? I know it's not ideal but just looking for a improvement over stock crap. Thanks!
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
4
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
That or with a TB, you either have an amp, or those early 2000 years on the full size tahoe, they were wiring them in series. It's most likely...
Can you sell the LOC and buy a head unit for that price that will do all of what both of those things would do?
7
Jadams
CarAudio.com Newbie
Jadams
NY
Jadams
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
