New speakers and home-made hpf
  • 1
portista
PT
Hi folks!
I acquired a pair of pioneer 4" (10cm) ts-g1032i (2 coaxial speakers) 30w rms rated. I have a HU pioneer mvh-160ui. These speakers seem to struggle with bass and I think I need to cut the bass on them. The HU seems to have a HPF but I think that it applies to all the speakers, so I think I have to make a pair of HPF to pply on the new speakers. My question is since the speakers are 4 ohm, what would be the ideal cutoff frequency? 300Hz?? What capacitor voltage and which type should I use?
Also I would like to install a pair of 6.5" (165mm) speaker set on the front doors. What suggestions do you have for me in the 50€ range? Coaxial ou 2 ways speakers?
Greetings
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
315
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
236
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
392
portista
portista
PT
portista
