New Stereo Install Interference
  • 3
DangrousDave20
Video of the problem here > https://youtu.be/b2AVNKmWHhU
Just installed a new Power Acoustik double din unit in a 2008 Pontiac Grand Prix GXP.My constant power, ground, and speakers matched up perfectly. I ran an Add a fuse to the fuse box for switched power. I used the Power Ant wire to power the amp (it's a monsoon system).
The sound you're hearing only comes from the front left speaker. Even with the sound all the way down its still present. The radio originally ran fine for about 4 days with a slight hiss. Then one day I got in the car, started it up, and this...
I've tried grounding the unit directly to the chassis of the car (used speaker wire and attached one end to the unit and the other to multiple bolts to see if one would remove the noise). Also tried grounding the rcas to the unit, and even removed the rcas completely. Still there. I've also tried multiple fuse slots to see if the one I was using (power sun roof) was interfering.
Here's a link to couple pics of the unit. As you can see the rcas are proprietary plug in the back of the unit. So I'm not sure how I would use a ground loop isolator in this case?
Help anybody!!!?
Imgur: The most awesome images on the Internet
I'm assuming you don't have an extra radio hanging around to check that its not just the H/U? Power acoustik is not the best quality...You happen to have a warranty for the radio or can return it?
And yeah I guess I could try and return it... I was hoping there was just something I might be missing? It's only coming from one speaker. I thought was a little odd. Any idea on how I would use a ground loop isolator in this case? Would I have to take leads from the amp, convert them to rcas, then run them through the isolator and into the back of the unit? Or would using a GLI not even work in this case?
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
193
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
671
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
578
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
653
DangrousDave20
DangrousDave20
Illiniois
DangrousDave20
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
