Ok, I am upgrading my head unit to a Pioneer AVH-X2800BS. I still have the stock speakers, and no sub/amp at the moment. I used solder and heat shrink on the harness, no crimp connectors or anything, but I cannot get it to power on. I have double checked my wiring and it looks complete. I am not using the Reverse, Mute or Amp wires (on the Pioneer side of the harness). I am also using a Micro Bypass to bypass the parking brake. I noticed I screwed up and ran the blue wire from it to the universal harness (not the stereo side), which is to the amp. I need to fix that, but I don't think it would keep the stereo from powering on.
I am thinking it has to be the ground. I do not have a good spot to ground to body in the dash opening, and am using the ground from the original wiring harness. I posted about that on here already, and was told that was ok. I have the ground wires from the stereo, the universal harness and the Bypass soldered together.
If you guys have any ideas why I'm not getting power, let me know. Or, if I'm not explaining things well enough, let me know what needs clarification.
