new to forum and could use some help
  • 2
Okay so im having a problem wiring up 2 sets of componet speakers to a 4 channel amp i have everything all wired up and get sound everything sounds good tell i turn the volume down or have the aux pluged in and my speakers will sit there and move back and forth making a poof sound idk its really weird to me i unpluggd the rcas and it will stop and also if i toggle the switch between hpf full and lpf it will stop in hpf and if i have one in full and hpf idk whats going so if someone could chime in and give me some input on what it might be
its a pioneer head unit deh-x7500hd and re audio xxx 6.5 components and re audio usx 4250 4 channel amp
recheck all wiring , make sure all is in phase ,also check all connections as well ,make sure nothing in the doors is touching is touching metal to
ive checked twice now on all wires to speakers and and rcas even checked ground on amp and deck now im trying the rca wire rap to see if that resorts it out i dont think it has to do with wiring cause if i flip the switches on the amp to high pass filter or hpf instead of full range it doesnt do it anymore idk though could be wrong
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
Not a whole lot of action on that front here if you're interesting in antique collecting. The hoarders have been collecting for a long time now...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
480
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
535
sirwilliam
sirwilliam
salt lake city, utah
mylows10
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
