New to me truck, came with alarm, couple questions.
  • 2
YoungBloodM50
Colorado
So I bought a 2001 F-150 the other day and it came with a viper 790xv alarm system/ remote start. I really want to take off the camper shell it came with but I know that the alarm is hooked up to it.
Will I have any problems with this?
Should I just take it to a shop?
And about how much typically would a shop charge for service on something like this?
I would also like them to reset it because there is no info about custom codes etc. Thanks for replies.
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
619
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
YoungBloodM50
YoungBloodM50
Colorado
YoungBloodM50
