New to the forum and need some help.
  • 5
nugget31
CarAudio.com Newbie
texas
Hey guys so i decided to join this forum to try and get some advice on what im trying to do with a new setup
my current setup is
sundown audio SFB 1500 watts
2 DB drive 12inch 600rms each in a prefab ported box wired at 1ohm
Big 3 upgrade
JVC head unit
what i want to do is take out my 12's and put a custom sealed box with 6 10in subs, 200rms per sub
all will be wired to 1ohm
This will be going into a 2009 tahoe
do you think it would be a little more louder / clear or is it a waste of money?
Thanks!
Why a sealed box and why 6 10" subs? How much space are you willing to give up for a box and how much money are you looking to spend? Typically less is more and especially at the 1500W power level you have an awful lot of options for say a single 18" woofer that'll get you places.
I was going to suggest 2 15's but 1 18 works too
That 1500 watt amp actually dynoed at 2200 watts
Doing 6 10's sealed with 200 watts a piece suggest an SQ build
But you have a Tahoe, all that space.
You should be rattling the pictures off the wall when you drive by
Im looking to spend around $500 for subs and box... The box I will be making myself which is why I wanna do sealed since im not an expert and im not to sure on how to make a good ported box
My idea is That the 6 10s would be louder then my 12s and would have clean bass... But im not sure honestly I never thought about doing 1 18in
You never mentioned how much space you want to sacrifice for this. Do you own some woodworking tools, glue, caulking, screws or will you have to buy absolutely everything to get a box built? Most manufacturers should have some box design plans posted in their websites, and most of the good high power subs these days are designed to function best in ported alignment.
Doing an Aero-Ported enclosure may be a suggestion to you as well to save some space and get some tuning involved to make those tens sing a little bit also. Six tens should get down pretty good . Ive ran four sealed tens back in the 90s in a single cab. Two down low behind the seat and two angled enclosures inverted just behind the head rest which gave me room in between for the sub amp to stay fairly cool. Old StillWater Kickers. Pretty impressive during that time and space I had for the sub stage
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
Not a whole lot of action on that front here if you're interesting in antique collecting. The hoarders have been collecting for a long time now...
Have you spoken with one of the reps? They should have all that info on file.
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
646
nugget31
CarAudio.com Newbie
nugget31
texas
Buck
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
