New truck, new subs?
  • 3
ilikeradios
Just got a new to me F350 Crew Cab.
Currently running 2 Skar ZVX 8's on 2k watts in a small truck.
This 350 is WAY bigger but I do not have a lot of power to play with as I need to keep it under 200 amps so 2k watts.
i have the room for a pair of 12's as I am ditching one of the rear seats however I just dont think I have the power needed by most 12's these days
My box builder is pushing for a pair of 8's in a 6th order box.
I think a pair of 12's in a standard slot ported would be better (I just want output)
So use my 8's in a 6th order or a set of 12's (no idea the brand, something that needs just 1,000 watts each)
Thoughts?
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
8
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
4
419
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
ilikeradios
ilikeradios
Pigeon Forge, TN
ckeeler11
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
