New wiring for a new alternator
  • 2
I'm looking for some info on what gauge wire and fuse I should use to replace the original wiring when I install my new high output alternator. Can anyone point me in the right direction for this?
What the amperage rating of your alternator? You will want to use 1/0AWG OFC, which is rated for 300A. Many people don't fuse from alt to battery if they are both under the hood, but if you do, use a 300A fuse. If your alt is rated for over 300A, you will want two runs of all wires. Go with RAM_Designs for a kit, custom made:
http://www.caraudio.com/forums/electrical-wiring-classifieds/555346-custom-big-3-kits-ofc-cca.html
There's a fusible link in there originally. I was thinking it was there for a reason so I should probably put a fuse in there. I only got the 180 amp; since the system I'm building isn't as big as some of the guys on here. Plus when I'm using the trail welder or air compressor I wont have the radio on anyways.
It's up to you man, fusing is always safe. Many don't run a fuse up there, I know I don't, as there is fairly minimal chances for a short. Either way, 1/0ga is the wire size you will want. 300A fuse for OFC wire, 250A fuse if you use CCA. If you decide on RAM_Designs, he'll take care of you. Or you can do it yourself, it's not hard.
What the ****? Are you trying to put ohm's law into very complicated verbiage?
6
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
226
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
636
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
665
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
659
militarymisfit
militarymisfit
Guam
gckless
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
