newbi needs help !!
xplorer00
hey wats up? im kinda new at this and i need some advice, my amp keeps cutting out on a hard beat i just need to know where to start at....... i have a Pioneer gm5100 witch is bridge and bestbuy special dual subs, lol with a panisonic headunit, stinger wiring, im open to any suggestions, thanks
Is your gain and bass boost all the way up? It sounds like you may be trying to pull more juice than you actually have, or you're impedance is too low for that amp. What ohm load are your subs wired to?
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Problem resolved - Found a scrap Astra that was fitted with that same unit. Salvaged the Display and original plugs and wired it up on the dining...
Honestly I'd run an audio control DSP or a helix DA helix DSP but if you want to run a app with the DSP that's fine too it's fine too but the LC8...
991
xplorer00
xplorer00
Okahoma
xplorer00
