Newe Jensen MPR419Q Does Not Power Up
  • 1
smcotton
CarAudio.com Newbie
Just purchased the MPR419Q. Installing into my motorhome. Spliced in the wiring harness based on the diagram. It is all pretty straightforward. The unit does not power up. My tester shows current on the red wire. There is no current on the yellow. No current on the black. I tested the fuse at the back of the unit and in the motorhome fuse location. Both fuses are 10 amp. Both fuses tested good. I swapped out both fuses to make sure. I have tried current on the yellow wire with the key turned to the accessory position and the start position and with no key in the ignition. Thoughts?
File this one under “Who Would Have Thunk It?” The fuse to the solar array blew (for some reason). That was causing a dip in power to certain systems in the RV. While the red ignition wire to the new stereo showed 13V, the yellow hot wire showed only 4V. After replacing the solar fuse, everything is fine. And for the record, the new Jensen unit paired with 4-way Blaupunkt speakers is pretty darn cool.
No. Unfortunately, this seems to be a common issue with the Jensen Car1000. I have one that is less than a year old that gets stuck some days. I...
Not to deflate your ambitions, but here is a reference: https://www.simplyspeakers.com/Altec-6-x-9-3-Way-Auto-Speaker-Sold-Out_p_639.html Not...
Crutchfield is really good about that sort of thing. Not the cheapest prices but you know where your money went if you ever have any technical...
  • Locked
Nice crossover ..i have one it matches my Jensen BBE amps ....
9
smcotton
CarAudio.com Newbie
smcotton
fuquay-varina, nc
smcotton
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
