No 90* angles??
Corsica
Okay how do i take my box and make it so it has no 90* angles?? Does it do that much for you in the way of hit and sound quality?? Does it do anything negative to your box?? And what materials do I use??
Thnx for the input.
J
i dont personally think that it is "Harmful" per se'
All it would do, if anything, is reflect the sound in the direction if the hypotenuse (Angled board)... If this is a sub box, then it shouldnt matter wether it is no 90* or not //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif at least that is what seems to make sense to me.
Unlike full range tower speakers, sub boxes car only about the internal air volume. Unless you are making a HUGE box, internal waves shouldn't be a problem even if you use all 90 degree angles. Any materials would work that works normally; the only difficulty would making the right angles to join everything and I am one lazy bastard that hates triple checking every calculation for a regular box.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by Corsica Okay how do i take my box and make it so it has no 90* angles?? Does it do that much for you in the way of hit and sound quality?? Does it do anything negative to your box?? And what materials do I use??
Thnx for the input.
J
Don't matter my brother. 3/4" MDF //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What I mean is, I have a box with a ton of 90* angles in it. Can i use Duck tape and make it into no internal 90* and if i do this will it change the dound in my box???
J
Originally posted by Corsica What I mean is, I have a box with a ton of 90* angles in it. Can i use Duck tape and make it into no internal 90* and if i do this will it change the dound in my box???
J
It won't make any difference man. Don't waste your time //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Corsica
Corsica
Ft Huachuca, AZ
Corsica
    May 31, 2024
    May 24, 2024
