O hello midbass
  • 3
So I have two 4" coaxial speakers on my dash and two 6x9" coaxials on my rear dash along with a 12" sealed Fi. The 4 speakers are all getting 45 watts RMS each from an amp and the sub has 1000 RMS. I have turned all crossovers leading to the coaxials off so they are getting a full signal straight from the amp and they have no midbass at all.
The bass is either really deep or none at all and it's pretty annoying. It's obvious that there's stuff missing from songs and I really don't know what to do other than buy new speakers?
You want the crossovers for any mids to be around 80hz. Forcing speakers to play anything lower than that can really mess up a lot of the sound.
Yes, they were set around 80hz before but there was no midbass at all :s
I spent about an hour trying all different crossover settings and different attenuation levels and I just can't get the highs to blend in with the sub.
If anyone has any suggestion, I shall try it.
Personally I would look to focus on your front stage. Once you start getting out of bass frequencies, the sound becomes directional (i.e. you can tell where its coming from). Your front stage uses 4" coaxials. For one, a 4" speaker isn't going to have very good midbass response. Secondly, as it's a coaxial, you lose some cone area because you sacrifice a place for the tweeter to sit. For a first step I would at least switch over to some 6.5" coaxials, if your door can't fit it you might have to cut it out. Deadening is going to help a ton for midbass but I wouldn't start dumping cash into deadening if you're only uses 4" speakers
This pretty much confirms what I thought. Was hoping I could get away with 4" but it's not working lolz. I will get some 6.5 component speakers. Thanks for the help //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
midbass is more than deadening and cone area. midbass requires airtight seals between the listening space and rear cavity. your dash lacks a sealed cavity so no speaker in there will give midbass until you seal up the airspace. even a 4" can play midbass if it has a sealed cavity.
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
Welcome man. I myself have enjoyed this Hobby for many years as well. Nothing like some great tunes and getting them to sound good in a vehicle...
https://www.ctsounds.com/collections/ct-series-amplifiers/products/ct-150-4d Great 4ch amp. Id look at some Polk DB and even MMseries components...
I only have 1 jeep left now my old Comache ..to pull my black Ford out if it gets stuck ....
6
Chromite
Chromite
Los Angeles, California, United States
keep_hope_alive
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
