O-scopes!
supereikenator
For what price can a reliable one be had? I've heard the DMM method of setting gains isn't the most reliable and I really want to do my stereo right this next time around, so
I want to set my gains with a scope. I don't know what ones to trust though, any links? Thanks in advance! I can't afford the SMD tools so please don't suggest those, I know they exist and are great, but they are so ungodly expensive(from what I've seen.) this will be my last build for a while so the investment wouldn't be worth it for me either.
Dso nano works great $65 ebay
Yep, and there's at least three different versions now as well (or generations if you will). The oldest ones are cheaper, the newest is like $90. Biggest downside is only having one probe but for what you'll use it for that doesn't matter. Mine has served me well. Helped me figure out I was clipping.
Display 2.8″ Color TFT LCD
Display Resolution 320×240
Display Color 65K
Analog bandwidth 0 - 1MHz
Max sample rate 1Msps 12Bits
Sample memory depth 4096 Point
Horizontal sensitivity 1uS/Div~10S/Div (1-2-5 Step)
Horizontal position adjustable with indicator
Vertical sensitivity 10mV/Div~10V/Div (with ×1 probe)
0.5V/Div~100V/Div (with ×10 probe)
Vertical position adjustable with indicator
Input impedance >500KΩ
Max input voltage 80Vpp (by ×1 probe)
Coupling DC
Trig modes Auto, Norma, Single, None and Scan
Functionalities: Automatic measurement: frequency, cycle, duty, Vpp, Vram, Vavg and DC voltage
Precise vertical measurement with markers
Precise horizontal measurement with markers
Rising/falling edge trigger
Trig level adjustable with indicator
Trig sensitivity adjustable with indicator
Hold/run feature
Test signal Built-in 10Hz~1MHz (1-2-5 Step)
Waveform storage SD card
PC connection via USB as SD card reader
Upgrade by bootloader via USB
Power supply 3.7V Chargeable Lithium battery / USB
Dimension (w/o probe) 105mm X 53mm X 8mm
Copied from: DSO nano - Pocket size digital storage oscilloscope DSO nano - the cheap, low cost micro digital storage oscilloscope [TOL114C3M] - $89.00 : Seeed Studio Bazaar, Boost ideas, extend the reach
Has anyone here ever used the Oscium oscilloscope for the iPad/iTouch/iPhone? It looks like a pretty sweet device, and a lot better than using a 30 pound, full fledged scope, as long as the functionality is accurate and reliable. Here's a link for anyone who hasn't seen/heard of one.
Oscilloscopes | Oscium
I downloaded an O app for my phone. I wish there where more people that would test these out with real machines and see if its even in the ballpark to use.
I havehttp://www.ebay.com/itm/Velleman-HPS140i-Handheld-Pocket-Oscilloscope-with-X10-Probe-Included-/151165076534?_trksid=p2054897.l4276 and i've been pretty happy with it so far. Haven't really tried others though to know a difference. I has a backlight, and easy to see display, lots of settings, and can also show rms wattage as a readout. although it is a little jumpy.
Get some of your friends that have systems to pitch in and tune a bunch of systems with it to offset the cost //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
supereikenator
supereikenator
Strafford, MO
Jmez36hz
maylar
    Jun 2, 2024
    Jun 1, 2024
