obcon single 12 box?
What he^^ said. Let's put it this way, if the company doesn't disclose a tuning, it's junk because any company putting the time/research into building a proper box will know the importance of tuning and will advertise it. What I will say is that it, like most prefab ported enclosures, is likely tuned VERY high.
Box is more than likely too small and tuned too high. I wouldn't touch it, or allow my friends to touch it.
Friends don't let friends buy prefabs. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
if you were to test a prefab from a custom box , you will be impressed in how much of a difference their is. It is a dramatic change in how much more quality you will get from your sub. I personally think it is worth it to pay for a custom box.
eh I'm probably just gonna play with it. it can't hurt much.
Get measurements of the exterior box size, material thickness, length of the ports, and the diameter. Im sure someone could crunch some numbers and figure it out.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
659
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
989
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
Bass Infection
Bass Infection
Wisconsin
chillin
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
