Odd issue with 05' RAM 3500 Quadcab head unit install
  • 1
jinjuku
Ordered a Kenwood KDC-X399 for a 2005 Dodge Ram 3500 Quad Cab. 7 Speaker Infiniti factory system.
Also have the Metra/Axxess CHT0-02 adapter to tie the receiver into the factory amp.
Also have the ASWC-1 Steering wheel adapter.
I wired up everything according to the Metra user guides. All connections are soldered and heat shrinked. Unused are snipped flush and also heat shrinked.
Audio sounds fine and continues to do so.
BUT when the volume hits 27 or above. The ABS light goes on, gas and temp gauges go to zero and headlights come on. When the volume is turned back down ABS and gauges come back.
I have quadruple checked the Wire harness. It's totally by the book. Reset the CHT0-02. Unplugged the steering wheel control adapter and even cut the brown mute Wire per Crutchfield (they've been great BTW, awesome support). They are sending out another CHT0-02.
Looking for any insight and figured the more eyeballs on this the better.
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
It sounds like the remote is wired to the interior courtesy lights. Those lights come on as soon as you remove the key from the ignition. Try...
175
jinjuku
jinjuku
Cleveland
jinjuku
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
