Odd reading when setting gains with multi meter
  • 4
I was setting the gains on my amp a boston gta-704 rated power is 70x4 watt rms and I was setting it to 65 watt rms at 4 ohms the math says the multimeter reading should be 16 or so I rounded down but to get this reading I had to turn the gain up to around 3/4 and on just about every amp I have had the rated power is much closer to half way turned up any ideas why it has to get turned up so high to achieve rated power thanks for any advice
The gain knob position depends on the preout voltage of your HU, the input voltage range on the amp, the level of the source recording, and the volume control setting.
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
It sounds like the remote is wired to the interior courtesy lights. Those lights come on as soon as you remove the key from the ignition. Try...
2.9 is not an uncommon (Re) DCR reading for a 4-ohm driver. On the low side but well within what would be considered well with the norm. If your...
5
Quinn88
Quinn88
Eugene, Oregon
Jeffdachef
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
