Off brand subwoofers....Dont shoot me.
treiber67
Lets say I new someone that might be looking to do another budget setup and wanted to obtain 4 15's for around $300.00 What would be some good suggestions. I hate off brand as much as the next guy but which ones going to hold up best. I did some research on lanzars max 15 and they seem to work rather well...any input here?
If your only running 2k then u don't want 4 lanzar max they are a 1000rms each and can fully take it all day...they are not nearly close to being as crappy as price indicates
I am going to go out on a limb and say that most of the responses will be to save up and spend more for 2 subs and maybe more power instead of 4 lower quality drivers.
I wouldn't say that cone area alone is worth it if you can find a DECENT set of woofers..cone area>power
He could run 4 of the Lanzars on 2k. It would be a loud, cheap budget setup. I've heard 3 of the 12's in action. Kid was running them on a Kicker zx1500.1 and they got pretty loud for 45 dollar subwoofers.
The Lanzar Max series subs are great budget performers. Used the 10's and 12's myself and had great results. The 15's I believe are rated for 1200 watts peak. No rms rating given but they should handle 600 rms and have no problem holding that power. My 12's handled 500 rms all day long and the 15's have a bigger voice coil(2.5" on the 15's and 2" for the 12's) . Q-Power Deluxe subs are another great budget option
Here is the Lanzar Max on Lanzar's site : Lanzar - MAX15D - Max 15'' 1200 Watt Small Enclosure Dual 4 Ohm Subwoofer
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
368
6
338
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
treiber67
treiber67
ft.lauderdale fl
Jimmy Rustler
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
