Ok So i Have a Suite Alpine system do I match it with an Alpine Headunit or go Kenwood
  • 3
TSegreti
CarAudio.com Newbie
4
How critical is it to match the brand of amplifier and speakers you have with the headunit.
Alpine is just so expensive but i already have invested a set of 4 spr 100w rms speakers a
4x 100 rms amp the pdx-f4 and want to get a better head unit but alpine doesn't seem like the best fit for my needs will
I suffer loss of quality or synergy?
I've been around car audio for over 30 years.  It's not critical that you match all your components by brand, but know manufacturers build their product to work best with each other.  Sound quality is a very subjective thing, but in my experience Alpine source units have the best sound quality and user interface.  Yes, Alpine is expensive, but so are premium brands in every industry, like Apple versus HP.
If you think an Alpine source unit isn't for you, ask yourself what you're looking for.  Make a list if you have to.  Kenwood has good sound quality and tons of features per dollar.  They're also very reliable.  I don't have much experience with Pioneer.  I know they're reliable and have great FM tuners.
I recently switched from a Kenwood Excelon 893S to an Alpine iLX-207.  I had to turn my amplifier gains down a little bit even though Kenwood touted 5V RCA outputs to Alpine's 4.  Alpine's HD tuner is better too.
The PDX-4 and type R speakers are a great match.  I worked with the engineer who designed both.
DON'T cut corners with your equipment.  Be patient and save up as long as you have to.  It's easy - you get what you pay for.
Good luck choosing your gear.
it doesnt matter if you stick with the same brand in the slightest. Just make sure that the deck (headunit) has the features you need such as network mode (active crossovers), at least 13 bands of equalization if graphic or 5 to 7 if parametric, at least 4 volts pre out, time alignment etc etc
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
488
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
703
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
TSegreti
CarAudio.com Newbie
TSegreti
youdoofus
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
