Old School Lighning Audio S1.1000D
  • 6
etm34
Kentucky
Old School Lightning Audio S1.1000D
Used of course, has some goods and bads
Bads:
  1. Has a tad bit of Rust forming on some of the screws
  2. The gain knob makes some noise when turning it, once set its fine
  3. Bass knob that doesnt like to stay on, didnt really mess with it
  4. Fan always stays on even when car is off, tried to figure out how to make a circuit for it but just didnt have time
  5. Missing two terminal screws
Good:
  1. No rust on the frame
  2. Internals are spotless and look great
  3. Works perfectly and has no problems at all!!!
  4. Has the fan upgrade which allows it to run at 1 ohm.
  5. Has stock bracket that covers the fan spot so the fan can be taken off
PowerRating: 600 x 1 @ 4ohm
1000 x 1 @ 2ohms underrated power of course
Frequency Response: 10-250Hz
Input sensitivity: 130mV -3.5V
Signal to Noise Ratio: 90dB
Crossover: Variable 50-250Hz
Crossover Slope: 24dB/Octave
RCA Pass Through
$240 shipped for some old school goodness
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
etm34
etm34
Kentucky
etm34
    Jun 1, 2024
    May 31, 2024
