Old School Rockford Fosgate Amp
SoCaL081
50
Hey guys I recently got a old school Rockford Fosgate Punch 360a2 amp and could use some insight on how I should hook up my single 12" Eclipse SW8122DVC 4ohm dvc sub. I currently have the sub wired to 2ohm from my last amp but was wondering how I can get the most out of this old school rockford amp with this sub. Ive also heard these older rockford amps are highly underrated and was also wondering how much this amp actually produces...Anyways should I leave the sub wired to 2ohm and bridge it or? It says bridged is 4ohm but each channels can be 2 or 4ohm so I don't know how I should wire and hook it up. If not bridged, what about wiring each 4ohm coil to separate channels or no cause it has 2 gain controls for each channels  (left side gain & right side gain). Hopefully someone can help me out. Thanks for the time.
2 ohm bridged will be running it below what its capable of.  Might be fine, might blow up, im not familiar with thosr amps.  Safest is to run it at 4 ohms per channel.
4 ohms stereo, 2 ohms stereo or 4 ohms mono are your options.
^^^^ this ^^^^
i sold these things new back in the day and theyre actually pretty solid
people need to state how many ohms each coil is instead of "4 ohm dvc". Its a dual 4 ohm coil sub, so you can wire it up to 8 or down to 2, neither of which is ideal for that amp. Get a different amp or a different sub. Or keep the amp and get another one for this sub
I wouldn't run it at 2 ohm bridged, especially since it's old. Those amp are not cheap to repair and you'd be better off selling the amp and getting a mono block. Once you blow that amp you lose 70% of its value.
You  can run it at 4 ohms per channel if you just want some complimentary bass and not output. But don't expect it to be loud.
or hoard it and just get another as well, because MOAR AMPS!!!
i have a bevy of amps that im going to be putting up on the wall of my makeshift man cave/spare bedroom in my house
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
SoCaL081
SoCaL081
youdoofus
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
