Omg!Did I just ruin my new Limitless lithium
  • 6
My63bug
I don't have the lithium charger yet. Kids are getting it for me for Christmas. So for its first charge . I threw it on the regular charger was supposed to keep my eye on it as to not overcharge it. New multimeter wasn't set right.. long story short I put 17.5 volts into this lithium.AND I AM A DUMMY.. Was told do not go any higher then 14.9 volts. Once I realized the mistake I quickly threw it into my Honda. Turn on the bright lights and anything else that would draw Power. Within a few minutes I got it down to 13.5volts. I hope I didn't smoke this battery I will cry. What do you guys think
the new 25ah
Id deff. check the entire casing for any swelling or Joint seperations..I think it may be alright as you sound like you may have caught it quick enough and got it back down.. Prob wouldnt hurt to place it in room temp..of about 60-75* on a paper bag or some brown package wrapping paper for a couple days and see if it leaks/leaves any dried stains.Its almost one of the same issues I had in my 90 240 sx with an Alt that reached beyond Redline/pegged way out around 16+ while driving in Traffic.I turned everything on I could find to get it down to an acceptable level to get home.Wipers,Lights, HU,A/C full Blast to playing with the Up and down switches constantly for electric windows.Turned out Everything was fine after replacing the Alt. Even the Batt. survived the insident
how long was it like that for?
Lithium has no forgiveness outside of spec that high if it had any decent current behind it.. Probably anything over 0.2C is bad that high.
You'll greatly shorten it's cycle life. Only thing you can do is use it and see how long it lasts.
Since regular chargers dont CC-CV, i'm assuming it took a hit.
Overcharging lithium is more damaging than severe undercharging. It will greatly diminish the lifespan of cells. One of the selling points of lithium is longevity. Some of these companies are saying 10-12yrs on a lithium cell under normal conditions
Dammned that sounds good!! I usually dont eat out. But Hmm. Tempting
91
5K
Ya man. Thats No Good. As Stated. More than likely blew the power supply. I had an amplifier behind a rear truck seat and I forgot about the...
5
999
Yes, it was designed with the help of Steve at Amp Medics. They are great amps, I have many friends that run them.
5
Send it means play it. I didn't say send it back. I'm sure it's fine.
43
5K
Thinking I will go 4th order. 3- 1 if i have the room for it. Motors to the front to help them cool faster.... and we are painting the baskets to...
12
My63bug
My63bug
Vacaville ca
kr15
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
