One side louder than the other...need help!
  • 4
Adnan
Hey guys for the last week or so I noticed that my driver's side component speakers sound noticeably louder to the point I can't even tell the passenger side is playing at all at times.I have to compensate by sliding the balance to between +2 to +5 on the right side in order for it to sound somewhat even again,but it varies per track. I have not made any changes to my system recently besides pulling the deck out a few weeks back while fixing an unrelated problem.
my setup consists of the following :
alpine 9835 deck
zapco iforce 2100 2 chan for mids
no rear fill
image dynamics csx 6.5 components running passive with supplied crossovers ( tweeter is set to 0)
15" ab xfl
e.d nine.1 sub amp
So far i swapped rcas between the sub and mid amp, switched polarity on the speaker wires at the amp inputs and it made no difference
Anyone else experience similar issues? what are the odds the amp might be screwed up?
Appreciate any tips or suggestions
Check just playing the tweeters. If one tweeter is louder than the other with balance set at 0 and fade at 0 send me a PM
Swap L&R RCA's on the amp, see if other side loses volume. If it does then it's the amp. Also try ipod directly to amp to verify it's not HU.
i'll try that tomorrow thanks
I've tried that as well, the left side is still louder i'll try connecting my iphone directly to the amp tomorrow
thanks for the suggestions
did some work in the trunk the other day and pulled the amps out for a while,after putting everything back together the problem went away
i set my time alignment back to the ideal distance and everything is perfect again,thanks for the help
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
986
I'm going to do a wood roof tomo but I don't want a shitty looking interior like most of the ppl I see doing it. What is the best thing to use to...
Sounds like you shorted the other channel so check you connections. Don't ask just look. Will solve your problem Every time. If you ever short out...
Adnan
Adnan
Toronto,On
Side Show
