One Sundown SA-15 or two Sundown E-15's?
  • 2
It all depends on your power, enclosure, how much room you have to work with, etc.
If you have the electrical and spacial capabilities, I'd go with the two E-15s. Assuming that they're both in optimal enclosures, the E-15s will probably end up out-performing the single SA-15 due to having double the cone area, and two motors running instead of 1. Again, it totally depends on the enclosure and electrical setup, but that's the route I'd go. If you have plenty of room to work with, I'd go with the E-15s. If you're crunched for space to the point where you're not going to be able to give the Es the room they need, I'd say the SA.
By the way - if you end up running the two Es, I'd invest in a larger amp.
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
650
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
3K
supereikenator
supereikenator
Strafford, MO
Full Tilt
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
