Optimizing my home theatre with car audio? Help me...
  • 1
Experts,
Can you tell me how I should go about optimizing my system. I'm using car audio equipment in a home theatre set-up. So hopefully I'm posting in the right place. My receiver is an Emerson home CD player with RCA to a kenwood kac7201 or an eclipse ea2000car amplifier. Powering the amp is a computer power supply unit 550 watts and a 12" eclipse sw62123.4. Which amp should I use? One seems to over power, while the other under powers. I've been trying to read up on how other people set stuff like this up in their homes. I've seen stuff about line coils etc....can someone give me a rough idea of what I'm looking at for a "descent" set-up? What I'm also trying to figure out is do I need something else? I have this up and running and am not quite satisfied because I can hear voice through the sub. Does this mean my low pass filters on my amp aren't doing their job and I need like a crossover or something? I also wanted to add one more 12" sub...is it ok if I find one that has the same rms (250watts) and impedance(4ohm)? The reason why I ask is because I can't find another eclipse 12" sw6123.4.
Thanks
Chris
Here is the plan. My car is on a bit of an incline, the nose is sitting about half a foot higher than the rear. The little bit of windshield...
6
590
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
5
I haven't had a proper home theater or home audio system in quite a few years but here's what I remember. I like both systems to perform the same...
14
Hey guys didn't realize this thread got revived. Decided to bite the bullet and buy a used Yamaha receiver. 6 channels 100 wats per channel with...
13
Tyrionmanister
Tyrionmanister
Columbus, Ohio
Tyrionmanister
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
