Orion HCCA-D1200 Mono Block Amp
  • 1
NIHL8ION
RUN ur car NOT ur mouth !
1,373
IlliNOISE
Item(s) for Sale: Used Orion HCCA-D1200 Mono Block Amp
Item(s) Description/Condition: Cosmetic: 8/10 Mechanically 10/10 - Amp works great, has never seen over or under voltages, and never ran below 1 ohm. (Currently Running @ 2 ohm on a single DD 12" 1000 series sub - Sub is Also FOR SALE as well). Amp looks Good & Sounds Excellent. They still sell these new @ woofersetc.com for $280 - Get yours for HALF PRICE !!!
Features:
*1200W Class D Mono Amplifier
*RMS @ 4 Ohm: 1 x 250
*RMS @ 2 Ohm: 1 x 400
*RMS @ 1 Ohm: 1 x 600
*Proprietary Orion Industrial Design with illuminated badging
*Massive loosely-regulated MOSFET power supply
*Mil-Spec Double Sided Circuit Boards
*Variable low-pass 30Hz to 250Hz
*Variable high-pass with INTELLi Q 20Hz to 150Hz
*10dB of boost with INTELLi Q
*Remote gain capable
*Selectable AUX out (Amp can be strapped to another HCCA-D1200 for 1200 rms @ 2 ohms)
*Fuse size: (2) 40 ATC
*CEA-2006 Compliant
*Dimentions: 11" x 10.2" x 2.4"
*Signal to Noise Ratio: -59dBA (reference 1 watt into 4 ohms)
*IntelliQ Bass Optimization Circuit and Remote Gain Control
*Heavy Gauge Direct-wire High Current Power and Speaker Terminals
*18dB/octave Low-pass Filter
Price: $140 Shipped (Lower 48 US)
Shipping and Miscellaneous Item Information: Included in the price
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). - Feedback Link: http://www.caraudio.com/forums/itrader.php?u=1028333
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
840
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
Ive had to install a 40 amp relay on the remote due to Popping issues on one my older Eclipse HUs, That ended up solving my popping issue. One...
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
NIHL8ION
NIHL8ION
IlliNOISE
NIHL8ION
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
