SOLD Orion HCCA-D5000 amps gotta go!!
loudsw2
music?? what music??
283
EH
i have 3 orions hcca-d5000 amplifiers that really need to get out of my room, these amps are barely used probably about 10 burps and a few songs worth on each at 1 ohm had these for just a couple months
$350 + shipping
no ref's im sorry i have nothing but buy one battery off a user from this site i have never needed to sell anything lol which specs are u looking for?
5000W Class D Mono Amplifier
RMS @ 4 Ohm: 1 x 1000
RMS @ 2 Ohm: 1 x 1600
RMS @ 1 Ohm: 1 x 2500
Variable low-pass 30Hz to 250Hz
variable high-pass with INTELLi Q 20Hz to 150Hz
10dB of boost with INTELLi Q
Remote gain capable
Selectable AUX out
Dimentions: 22.8" x 10.2" x 2.4"
Power Rating: 1000 Watts RMS x 1 at 4 ohms
Signal to Noise Ratio: -59dBA (reference 1 watt into 4 ohms)
Additional Power Output: 2500 Watts RMS at 1 ohm
Massive loosely-regulated MOSFET power supply
IntelliQ Bass Optimization Circuit and Remote Gain Control
Heavy Gauge Direct-wire High Current Power and Speaker Terminals
18dB/octave Low-pass Filter
ok going to drop to $425 shipped cause i need these gone, need the money and the room to get going with the new setup
Off topic, but did you notice if any of those amps have a different color metal finish? I have two off these bad boys and i got one dark skin and one light skin....
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
Ive had to install a 40 amp relay on the remote due to Popping issues on one my older Eclipse HUs, That ended up solving my popping issue. One...
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
loudsw2
loudsw2
EH
tangelo95
