P&J Audio
  • 3
Raven
Lacking social skills!
4,697
Michigan
Location: Dowagiac, MIchigan - Not listed on internet maps
Employees: 1
Review: Mixed reviews about this place. Wire is cheap, and the owner, Jim, will pull apart an amp and look at it for you for free, but all the equipment he sells is cheap Pyramid / Legacy / Pyle type stuff, just and he's full of ******** as far as giving advice.
My recommendation is if you need 8 guage wire, go there. If you need anything else, don't.
2/10
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
6
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
Raven
Raven
Michigan
squeak9798
1aespinoza
    May 19, 2024
1aespinoza
    May 19, 2024
