Passive Radiator question.
Today I learned about enclosure orders.
A standard bass reflex is considered a 4th order.
I learned that the bass roll off arguably defines the order of the enclosure.
Would this passive radiator represent a higher order enclosure? Because of its steeper roll off?
Passive radiator acts like a port, still 4th order. Additionally, roll off could be altered by changing tuning frequency, but it's still 4th order. I can alter the roll off a sealed enclosure by making it really big or really small - still 2nd order. The shape of the curve and roll-of on a 4th order bandpass can also be altered by changing tuning frequency. In the case of bandpass it's possible to have 2 different roll offs.
You know what. I could be wrong about dual passive radiators making it a 6th order bass reflex. The response curve does change using dual passive as opposed to 1, but they are pushing and pulling as a team. I think it's a 4th order bass refllrx.
The “order” is describing the energy storage. its like a spring with a weight on the end (2 orders of stored energy), or a piston with a push/pull component. The coil(spring) is stored energy and the mass of the cone is stored energy, so a sub in a sealed box is a 2nd order (2 components of stored energy). Adding a port acts like adding a second “piston” with a push/pull effect, making it a 4th order. A PR is the same as a port essentially, having a spring and a mass(the cone) it adds 2 orders of energy storage, making a PR enclosure a 4th order. Adding 2 PRs to a single sub would make it a 6th order bass reflex enclosure, not to be confused with a 6th order bandpass enclosure.
Super interesting!
Does this 6th order apply if there are 2 ports? Compared to 1 port (4th order)?
I think 4th order is correct. The 2 PRs just replace a larger single PR. I guess if tuned the PRs to different frequencies, then you could change the order.
Super interesting!
a 6th order has the sub (2 orders) a port (2 orders), and a port tuned to a different frequency than the other port (2 orders). There is also an 8th order, which is a 3rd port tuned to a different frequency than the other 2.
A 4th order bandpass/passive radiator. With the PR 18” would it sound more like a 12” Sub or a 18”Sub?
Because a 718 could be a better bass reflex for music. Like chopped and screwed rebased.
XCLSV Has quality youtube Rebased Songs. The music reaches lows!
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
12
I think this may be more of a home theater thing to just keep them from wanting to vibrate across the room by balancing them out. This may or may...
87
14K
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
755
Yep. It would be a little over 3 wired in series, but that’s fine.
814
Agreed. I was actually thinking of building a 3-way passive and I compared the cost to a Dayton DSP and it makes no sense to go passive.
10
Evyn1
CarAudio.com Recruit
Evyn1
Jimi77
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
