PG ROADSTER 66 - only 1000 built [ 5 channel ]
  • 4
SPLAudioHz
Indiana
Product Brand & Model:
Front 4-Channels Class A/B Key Features:
Triple Darlington power amplifier stages with complementary bi-polar output transistors
Built-in electronic crossover
Dual power supply design
Class D Subwoofer Channel Key Features:
High efficiency class D amplification
Remote low-pass level control (LPL)
Key Specifications:
Power Output . . . . . . . . . . 78W RMS x 4 @ 4 ohms + 650W RMS x 1 @ 2 ohms
Signal to Noise Ratio . . . . . . . . 85 dBA (reference: 1W output @ 4 ohms)
Frequency Response . . . . . . . . 20Hz - 20kHz
Effective Damping Factor . . . . . . 6.35 @ 4 ohms
Maximum Input . . . . . . . . . . 8.5V at clipping
Maximum Sensitivity . . . . . . . . 200mV at clipping
Crosstalk . . . . . . . . . . . . . -69dB, 1kHz, 1W
Bass Boost . . . . . . . . . . . . +18dB @ 45Hz
4 Channel Crossovers
Low-pass filter frequency response: 40 - 400Hz low-pass, 18dB per octave
High-pass filter frequency response: 40 - 400Hz high-pass, 18dB per octave
Sub Channel Crossover
Low-pass filter frequency response: 30 - 265Hz low-pass, 18dB per octave
Subsonic filter frequency response: 5 - 55Hz high-pass, 18dB per octave
Condition of all items:
USED
Total Price: :
$425 OBO
Shipping Terms: :
to 48, others email / pm for shipping costs.
Pictures: - Unless you are a Upgraded member, or your last 10 iTrader feedbacks are positive, you must post a picture of the exact item you are selling.
Anything you are specifically after? I have loads of items I don't want to list them all out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
798
SPLAudioHz
SPLAudioHz
Indiana
SPLAudioHz
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
