SOLD Pheonix Gold TLD66
  • 1
RidnClean
Love 4 Money
8,890
Washington
1. Product:
Phoenix Gold TLD66
2. Specs:
The Phoenix Gold Tantrum Series TLD66 line driver will enhance audio signal output from any factory or aftermarket head unit receiver. It will accept a signal from 1-5 volts and increase it up to over 8 volts. The result will be much better sound quality, unwanted distortion reduction, and a far improved dynamic range. Take advantage of the unit's 6 channel inputs and outputs, and prepare your audio system for a high quality 8 volt signal output for your front, rear and subwoofers!
The higher the preamp output voltage, the better signal to your amp and the louder your system will be able to go. It will also help offset the loss of voltage when driving multiple amplifiers from the same pre-amp output.
The higher signal level will also assist in eliminating unwanted noise from the vehicle into the audio system. For example, engine noise or whine that gets carried through the audio system will drop significantly or completely when the TLD66 is installed.
Don't be fooled by the low price. We bought a large quantity from Phoenix Gold and we got a special price so we're passing the savings to you. It's one of the best line drivers on the market. Phoenix Gold is one of the best companies in car audio and we've seen this line driver in both sound quality and SPL (loud) competitions. It's the best we carry and the lowest price... an awesome combination.
8 Volt, 6-Channel Line Driver
Independent 6-channel connections
Frequency response: 15-20000 Hz
Total Harmonic Distortion (THD): 0.02%
Signal-to-Noise Ratio: 110dB
Input impedance: 100 Kohms
Output impedance: 30 ohms
Maximum input or output voltage: 8 volts RMS
Power source: 13.8 volts DC
Dimensions: 5.2"L x 3.0"W x 1.25"H
3. Description/Condition:
great
4. Price: :
$60shipped
5. Pictures:
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
859
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
I just read the other post about this Bass Cube. IMO, it sounds like a signal leveler with adjustable Q. For that you can just use one of the many...
RidnClean
Love 4 Money
RidnClean
Washington
RidnClean
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
