Pick a Sub
Which 12" sub for SQ
  • SSA Dcon
    Votes: 9 34.6%
  • IDQ
    Votes: 10 38.5%
  • JL 12W3v3
    Votes: 5 19.2%
  • Boston G3
    Votes: 2 7.7%
  • Total voters
    26
500rms is a lot IMO. the IDQ will sound good off 300, im listening to 2 right now. could you really go wrong with any of those subs?
I was pretty much sold on the SSA, but I am not going to be giving it the right size enclosure (the box will only be 1' ias max) and I am not sure sealed is the right application for it.
I see FI has a new line coming out in 5 days....hmmmmm.....
NO!
But that's not really the point, is it? I am trying to open my mind and do a bunch of research before getting the one sub I will be living with for a ling while....
NO!
if your really into car audiom you won't keep it long. That itch to try something new will win!
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Shallow mount subs like those recommended are a favorite of truck owners. Typically the space under the seat is wide but “shallow” from bottom of...
230
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
554
Bubblebass
Bubblebass
SoCal
supermaxx123
Decebal
    Jun 10, 2024
